E08 error hoover dynamic next dxa 610aiw3/1-80
Home Forums Public Support Forums Help And Support Washing Machine Help Forum E08 error hoover dynamic next dxa 610aiw3/1-80
  • #93403
    CK1988
    Hi have an E08 error message on hoover dynamic next dxa 610aiw3/1-80 washing machine. It stops mid cycle and sometimes doesn’t drain fully so have to run the “drain and spin” mode to then drain it.
    Checked filter at bottom front and that was clear, Removed motor and cannot see any brushes so must be brushless motor. Need to check Tacho resistance tomorrow. Any Ideas???
    #454230
    cmckeown
    I have the same issue.
    I had the machine upside down to fix a cracked drum with some JB Weld (I’ve been doing it about every 18 months for the last 5 years ;)), and I was all chuffed with my glue spreading skills I turned it up again after a few hours of the glue setting and it wouldn’t work… 🙁
    I suspect water has got trapped in a sensor / water pressure switch or something and when I turn on the machine all I get is a flashing number 8 that goes across the screen and nothing seems to work.
    I too thought, it might be brushes as was suggested for other machines, but have also taken the motor out and there are no brushes on it. However, there is something like a sensor that is clipped onto the the back end of the motor (the opposite end to the pulley).
    It has served me well and I think there is still a lot of life left in it yet so I’d like to hear some thoughts on what it might be / how I can clear the 8 code that keeps flashing.
    Hope someone can help!
    #454231
    try disconnecting the heater and see if the code goes
    make sure wires cant touch or short out
    andyjawa
    Water blockage in the pressure switch hose since the machine was turned upside down? Yes your hoover has an inverter motor type set up. How did you get on, have you traced the problem and cured the machine?
