from what you are saying it only gives E10 when you use the hot air dryer but if you select a wash only the machine washes and spins ok with no problem
the dryer is a condensor dryer and uses a small amount of cold water to condense the steam. if this valve fail to open it will give this fault. it is a seperate valve and only used in the dryer
