E10 error on John Lewis washing machine during drying cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum E10 error on John Lewis washing machine during drying cycle
Viewing 15 posts - 1 through 15 (of 19 total)
  • #89130
    Odumont
    My John Lewis JLBIWD1493 washing machine displays an E10 error message 5 minutes into the drying cycle
    The manual says it might be the water inlet which is faulty which makes no sense to me as clearly water is going in during wash cycle and you dont want water coming in during drying cycle
    Very confusing
    I would really appreciate any help
    Olivier
    #440432
    aqualectric
    Re: E10 error on John Lewis washing machine during drying cy
    Water is taken in during the drying cycle to condense the steam. The valve is faulty.
    Unplug before investigating! :plug:
    #440433
    Odumont
    Thanks a lot for your message. However if the inlet valve was faulty wouldn’t it cause an issue during a washing cycle also ? (the wash cycles are going fine)
    Thanks a lot
    #440434
    aqualectric
    The valve has three outlets – two to the dispenser and one for the drier condenser. E10 is a family of codes for valve related issues; engineers will look in the diagnostics to get an E11, E12 etc. to identify the culprit.
    Makes little difference in this case as the valve is one unit.
    #440435
    Odumont
    Got it. Thanks again. Is it worrth replacing the valve for a machine which is 8 years old are shall I replace the machine ? Do you have a sense of how much it costs to replace the valve ?
    Thanks again
    #440436
    The valve (part no. 50297094000) is available online for around 24 quid. Far cheaper than a new machine I’m thinking. 😉
    #440437
    Odumont
    Thanks a lot Martin
    #440438
    Odumont
    isn’t this the right part though http://www.espares.co.uk/product/es1554 … Id=1131469
    #440439
    No idea as eSpares hide the original part numbers so you can’t price compare but, this is the correct valve:
    https://shop.ukwhitegoods.co.uk/5029709 … fill-valve
    Paul sparky
    Hi. I am having the same issue, so having removed the lid I can see the water inlet has 3 solenoids but all 3 go to the soap draw(wash compartment, pre wash compartment and stain compartment). I can’t see any pipes connected to the condenser. Is it still likely to be a faulty inter valve?
    #440441
    whats the model and pnc number of your machine
    you can check the valve coils with a multi meter if you have one. expect around 3 to 5000 ohms
    Paul sparky
    Hi Dave
    its a JLWD1613, prod no 914605613 00, Type FL10664M2
    I have measured the 3 coils and they all read the same
    Paul
    #440443
    ok well the fault can only be one of 2 things
    1 the valve is not being energised
    2 the valve is faulty inside and not opening
    Paul sparky
    Which of the 3 valves is for the drying cycle?
    is it possible to remove/inspect or swap with another as we don’t use the soap draw
    #440445
    you cant swop the valves as the one for the dryer is restricted so it only trickles in. Also you may nit use the soap draw but the machine still gets water through it
    follow the pipes and see if one does not go to the soap draw
