Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › E4 Error bush dishwasher
- This topic has 5 replies, 2 voices, and was last updated 6 years, 10 months ago by
Toolunch.
May 20, 2019 at 7:33 pm #95885
Toolunch
ParticipantHi Chaps, I have a Bush DWFSGX146SS from Argos, I first developed an E8 fault shortly after a glass broke in the dishwasher’ i decided to have a look and see if something was stuck in the drain pump’ i noticed a small piece of glass that had scored the impeller and surrounding and thought i had removed the glass, the fault kept occurring from time to time so decided to take another look’ after researching i decided to have a look at the diverter valve motor’ when i removed it a piece of glass fell out’ i was chuffed thinking I’ve fixed this, to my disappointment when switched back on the machine flagged up E4′ i thought it may be water resting on the flood switch after all i had it on its side. the was signs of water so decide to slightly put it on its side for a day to drain all water from where it should be.
Once i put back together the same E4 code appeared ‘ this time ive removed it to the garden in order to take a good luck whats going on.
Ive checked the flood micro switch which is working fine, it could well be the divertor valve since removing it has damaged the seal which is creating water and pushing the float switch to activate ‘ ive changed the seal on the divertor motor’ but not yet put all back together’ as oi want to give it a good going over first.have you any ideas guys ???
May 20, 2019 at 10:32 pm #461607electrofix
Moderatorfrom owners manual E8 is the diverter valve
May 21, 2019 at 5:11 am #461608Toolunch
ParticipantYes got that Dave, there was a piece of glass stuck in it, since I’ve had it on its side, it’s started to say E4
May 21, 2019 at 8:19 am #461609electrofix
Moderatorwell in that case I would check the overflow switch
you had it on its side and the switch may have got wet internally
May 21, 2019 at 10:12 am #461610Toolunch
ParticipantThanks Dave, I’ve tested the switch and all seems fine, the only thing I can think of is the water is leaking from the parts I’ve already removed, so will need to lift it up to see if I have a drip that’s forcing the polystyrene safety to trigger, that’s all I can think off
May 21, 2019 at 11:27 am #461611electrofix
ModeratorI would run it with the covers off and watch with a torch in hand
