Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › E4 error occurred after the plumber changed the pipes.
- This topic has 6 replies, 2 voices, and was last updated 2 years, 4 months ago by
bouletpr.
December 4, 2023 at 6:26 am #102421
bouletpr
ParticipantHi,
I have a dishwasher Whomson thominox silence.
It was working fine until a few weeks ago, but now I get an E4 immediately when it starts.
The issue started just after a plumber came to change the piping in the room.– Can it be related ?
I disassembled the machine, looking for anything unusual in it, and tested a few things, but everything seems fine.
The E4 error did not appear immediately when I restarted it. Instead, it did nothing for at least 30 seconds. During its working state, it was immediately filled with water. After the 30 seconds, there was some water sound. It’s likely a coincidence, but the water started to get in exactly when someone used the sink. The dishwasher and sink are next to each other and their pipes are connected.– Is it a pure coincidence or could the water intake from the faucet have triggered the start of the dishwasher ?
The E4 error reappeared after 30 seconds of filling with water. My guess is that I obviously removed some water from some components of the machine while trying to fix it. During the refilling of those elements by the machine, there was no error. But once it was done, it failed again.
Thanks for your help and sorry for my english. I hope my explanation is understandable though.
December 4, 2023 at 9:59 am #488778electrofix
Moderatorthe fault code point to a possible leak in the base
December 4, 2023 at 5:29 pm #488779bouletpr
ParticipantThanks for your reply. The plumbing appears to be leak-free.
December 4, 2023 at 7:31 pm #488780electrofix
Moderatorits not the plumbing
in the base of the machine, underneath where the motors are is a floatundo the covers and see if there is water down there
December 4, 2023 at 8:19 pm #488781bouletpr
ParticipantOh, ok, sorry.
I have already removed all the covers of the machine. It’s completely dry and clean.
MorganDecember 4, 2023 at 8:38 pm #488782electrofix
Moderatorok check the float in case its been dislodged and its pushing the switch
December 5, 2023 at 12:45 pm #488783bouletpr
ParticipantHi,
The plumber came back to check if all was ok on his part. It appears that there was a lot of limescale in the plumbing, leading to a really low pressure. After cleaning it, the issue was fixed.
Once again, thanks Dave for your replies.
Have a good dayMorgan
