e41 fault on zan w/dryer
  • #27139
    robbo1973
    hi all aint got the model number at hand it is the fully dig with display like iz.
    fault reported not washing properly ran thru test and the jet system was not firing water fully across the drum it was hitting door glass and runnig down. checked pump fine but manifold was clogged so changed but still the same.ran thrui test again and code e41 door aperture at fault ❓ what does this mean and how does it detect it :rolls:.
    thanx in advance.
    #212754
    helo_75
    Re: e41 fault on zan w/dryer
    someone would have tried to start a program without shutting the door
    since this would be the last recognised fault, it’ll stay there till its cleared
    might not help you with your present fault!!
    #212755
    robbo1973
    lady now saying e10 coming up in display any idea?
    #212756
    21rich33
    E10
    =water supply problem.
    Could be a number of things
    Taps not on
    Kinks in inlet pipes
    Filters blocked at water valves
    Water valve not operating
    Blocked pressure chamber
    Faulty pressure switch
    Or even a pcb fault
    The list is quite endless lol
    Richard
    #212757
    helo_75
    is it a washer dryer?
    #212758
    Thread title says so…… Model number would have been nice. You thinking dryer valve solenoid?
    robbo1973
    hi got model no wjd1667w.the main fault was not washing clothes the circ pump runs fine no blockages but the water hits the door glass and runs round instead of firing at clothes so not cleaning clothes properly what else would cause this. now it is also coming up e10. thanx for replies.
    #212760
    Simon46
    coin in entrance to pump?
    S.
    #212761
    robbo1973
    checked for coin and changed manifold anyway as full of smelly crap lovely.
    blew down pipe and clear but hits door glass.
    #212762
    helo_75
    its the green coil, on the 3 way valve
    #212763
    robbo1973
    i can understand yhe e10 fault solved by a solenois valve but the problem of the pump ❓
    #212764
    The spray problem is almost certainly a partial blockage in the jointing piece where the hose joins the door seal. Slip the door seal off at the front (and the front dryer duct) and you can pull it down for access.
