E52 on AEG L14510V1
  • #64890
    Pnc. 9145100922-00
    Initial complaint is a bit vague, customer says it works fine on Woollens 40° wash but stalls on most others.
    Says it does wash OK but gets towards end of rinses and then stops, no action and also said that the display goes back to over 100 minutes.
    Diagnostics throw up E52 but motor looks perfect, brushes hardly worn, tacho sound and when I run the machine on wash, rinse and spin it appears to work perfectly.
    I have had a quick read through previous E52 threads, is this likely to be the motor toc giving out on longer, hotter washes?
    martinm
    Re: E52 on AEG L14510V1
    does the motor have a low insulation resistance reading?
    sometimes this can cause an e52 alarm
    #358398
    Couldn’t get it right out to get the back off, just about managed to check brushes and tacho by tilting it back, not room to access motor plug, damned kitchen fitters. 😥
