Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › e522b fisher paykel
- This topic has 6 replies, 2 voices, and was last updated 12 years, 7 months ago by
robbo1973.
September 8, 2013 at 9:36 am #77027
robbo1973
Participanthi all i have one of these to looy at next week and was wondering if anyone has any info on them its constntly dispensing water and flooded the kitchen! im hoping just a stuck switch but if anyone has had thisi before
cheers chris
September 10, 2013 at 3:33 pm #400477robbo1973
ParticipantRe: e522b fisher paykel
Hi all been here today and the facial pcb is not responding to any touch but is constantly disp water and also the fan ain’t running even though the reed switch is operating fine and the light is going on and off,I’m thinking control pcb but as it retails at over £200 was hoping someone has had a bit ,ore experience than me on these?
Cheers chris
September 10, 2013 at 7:00 pm #400478johnmac11
Check the harness at the top of the door under the hinge cover, if it is Ok then it has to be either the fascia board or control board.
Post up the PN number and I will let you know the correct board if needed, £200 is way over the top and I would guess the board is well under £100
John
September 10, 2013 at 7:41 pm #400479robbo1973
thanks,i did check the harness and thats fine as well
product 23207-a
serial nut763206
model e522brxfducheers chris
September 10, 2013 at 7:57 pm #400480johnmac11
Hi Chris,
Make sure you slide your fingers up each wire from the harness plug to where the wires go into the top of the door, it might look OK but you will feel an internal break if there is one.
The main control board for that fridge is now part number 837765P and the retail price is about £85+VAT the user board is part number 821074P and retails at about £48 + VAT
If you need any more info send me a PM with your email address.
John
September 10, 2013 at 8:49 pm #400481robbo1973
Thanks john for the info but part no ain’t coming up on connect,I’ll check the harness when I return if its broken is that a new door?
I’ll pm you if I need any more infoThanks again
September 10, 2013 at 9:20 pm #400482johnmac11
The part number for the main board I gave you is the latest one, the previous part numbers are 817850P, 820504P and 820818P
Door harness is available as a spare part and costs around £16 ex VAT, part number is 814416P
John
