Early Indesit W103 PCB fault ??
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Early Indesit W103 PCB fault ??
  • #7114
    Pat-UK
    COD 215005350.20
    This is a new problem on me, anyone else seen or heard of it ?
    Put it on any cycle or spin, turn on, door lock clicks……… thats it nothing else
    Turn timer round to reset and turn on, LED does it flashy re-set dance as usual so the Panel is trying to work.
    All the symptoms of a faulty Door lock, I hear you cry. my thoughts exactly. Door lock swapped. same thing.
    I know it’s probably the PCB but before I send it off has anyone got any thoughts on it ???
    Thanks all
    #121474
    Re: Early Indesit W103 PCB fault ??
    check motor brushes (most likely, I know it sounds odd) before doing anything else. If not try for an open circuit pump (less likely but not unkown)
    #121475
    AMS
    Check the wires going in to the heater element for broken crimps. I’ve had this a few times and it has turned out to be a broken black wire going to the element.
    Hope this helps,
    andy_art_trigg
    On some Hotpoint’s now, if the motor is open circuit the machine “won’t fill or operate”. I don’t know if any Indesits are similarly affected though.
    #121477
    andy_art_trigg wrote:I don’t know if any Indesits are similarly affected though.
    Yep, sure are :tup: as with any modern electronic controlled machine, if the complete circuit is ‘interrupted’ then nothing works. What normally happens is that on first setting the programme there is a slight but noticeable ‘delay’ before it bursts into life. That is simply the EPROM circuitry checking all its dependant components prior to start-up 😯
    Try it for yourself next time on a perfectly (albiet rare) servicable Indesit, just disconnect the Motor Plug and switch back on…..I guarantee you will find it DEAD!!! 8)
    Bl**dy electronic nightmare really, don’t talk to me about Error codes either, that’s another headache, but somehow we have to make a living from this lot of modern wizardary :haier:
    By extrapolation, the machine is actually helping us by telling you that there is a fault prior to filling etc. Makes a bit of sense to me….. Much more sensible than trying to drag out a machine full of water and soggy washing!
    lotusray
    check for a broken wire esp around motor and ellement
