Type Ebac into the search bar at the top of the page, there is a bit of info there. I am yet to be convinced and won’t be stocking them any time soon. The roll out just doesn’t convince me at all.
Have only ever seen 2 changed a door seal on 1 and the other I couldn’t find a fault on. My opinion is that they are well made and have a quick wash for full load and all round look easy to work on
I supplied two Ebacs and both of my customers slated it. It doesn’t float their boats. I think they found it not so user friendly and the washing performances gives a lot to be desired. Which? doesn’t recommend them.
I have seen a few
1 with bearing failure
1 with pcbs fault and there is now a modified version complete with facia as you couldn’t spin and drain only in full program
1 with dispenser leaking water out of the front
2 with out of balance load..
generally parts from all over the world and assembled in uk.
Evening guys, how’s your luck doing? Tell me, who does repair work for Ebac washers in my neck of the woods? For the less well informed I refer to Berkshire/Hampshire.
