Edesa practica oven
  • #51608
    dell1
    Hi all
    I have a edese practica oven, and the inner class has come away from the metal door, its glued to the door. Is there a glue i can buy to fix the problem, or is it a new oven door.
    Cheers.
    #308731
    don
    Re: Edesa practica oven
    Hi dell1
    Click here for heat resistant glue for oven doors you will need to remove the door, make sure both surfaces are clean, weight the door down for 24 hours to allow the glue to cure, trim off any excess and refit door.
    HTH 🙂
    Don
    #308732
    dell1
    Hi Don,
    thanks for the info, will track it down tomorrow, Cheers
