Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ego/ Diamond H conversion
- This topic has 7 replies, 3 voices, and was last updated 19 years, 7 months ago by
cornwell40.
August 31, 2006 at 12:28 pm #20437
cornwell40
ParticipantWorking on a Leisure Rangemaster 110 and the grill reg is goosed. The new regulator from Connect is Ego but the old is Diamond H 33ERX22M. Looking at the conversion chart in the stickies, on the first S is pilot but on the regulator there is S1 and S2. Is this the correct conversion for those regulators or is there another one 😕
Tony C
August 31, 2006 at 5:14 pm #187078eastlmark
ModeratorRe: ego/ Diamond H conversion
Should have a piece of paper with that one Tony, bascily connect the wire that was on the Pilot connection on the Diamond H to S2 on the new Ego item, your then need to link P1 to S1 with a short link wire (also usualy enclosed)
4 and P2 should also be linked. can fax it over to you if you pm me a number.p1= brown live feed
p2= Blue neutral
4= blue neutral +wire link to p2
2= load A red
2A= load B violet
s2= pilot neon red
s1 link to p1August 31, 2006 at 9:05 pm #187079cornwell40
ParticipantRe: ego/ Diamond H conversion
Thanks Mark 😀 ,
I’ll go back tomorrow and finish it off.
It had already taken me nearly an hour to find all the retaining screws for the hob as they were under a quarter inch of grease, then I find out the regulators are different on the home straight :twisted:.
Tony CAugust 31, 2006 at 10:36 pm #187080eastlmark
If you got that as Gen fromconnect, i would complain as mine here have a conversion chart as well as the wire links all included in the bag.
September 1, 2006 at 7:54 am #187081cornwell40
It came in one of those small resealable bags with a handwritten label and a Yellow Connect label on it. A return methinks 😡 . I may have a word.
Tony CSeptember 1, 2006 at 11:14 pm #187082SWERV
The last one I had from connect didn’t have a wiring chart with it 😡
MervSeptember 3, 2006 at 11:19 am #187083cornwell40
Thought I’d have a word with Connect on this and see if they would send the sheet by email (just to see how bothered they could be).
Initial call at about 9.15 am and the C/S lad says they’ll email it out soon and credit the carriage as a goodwill gesture. Good on em I thought.
12.30 rang again, no record of it, start again and they log it as a complaint to be sorted asap.
Rang again 2.30 still not done.
Rang at 4.30, as its a complaint there is a backlog and it will be Monday at the earliest, as they have to contact the manufacturer for a sheet of paper.
Good job its not urgent eh!Tony C
September 3, 2006 at 4:46 pm #187084SWERV
Good old connect, I’m still waiting for a returns number(2 weeks)to send an order back that I had already cancelled twice!
Merv -
