Re: EKC 6045X electrolux oven
3871425124 is the part number for the correct 1900W Element, the higher wattage one will heat up faster but is designed for an oven with a different type fan. There is a possibility that your oven will encounter overheat issues in cavity behind, the 2400w element will go hotter quicker & heat can be transferrd through rear wall where there are 2 thermal cut-outs in element circuit which may go out every now & again. On the other hand there may be no issues.
