ELBA PX906 Cable overheating
Home Forums Public Support Forums Help And Support Cooker And Oven Forum ELBA PX906 Cable overheating
  • #41553
    bodrumkale
    Evening all, this has got me puzzled and embarrassed, I am a Spark by trade and tried to fix my daughters cooker, thought it was the thermal cut out, replaced like for like but still the problem persists. The plug from the cooker gets red hot , the live pin so I thought it was the thermal cut out.
    Is it the thermostat?
    Can anybody help before I buy another part I do not need?
    Al
    #270560
    helo_75
    erm, forgive me ,but , sureley that machine should be hard wired, not on a plug top?
    we’ve disussed this before, and ive never seen one on a 13 amp plug top, theyre always wired to a cooker point with 2.5 cable!
    #270561
    bodrumkale
    Re: ELBA PX906 Cable overheating
    Ah, you could be correct, this cooker came to my daughter with a plug top on it ( given to her by father in law) it has been used for over a year now without problem plugged into the socket (flex is 2.5mm cable) and it does not detract from the fact that the cable is getting hot as well as the plug top.
    At least with a plug top it is protected by a 13a fuse.
    #270562
    helo_75
    yep, but it overheats and is a potential fire hazzard
    #270563
    bodrumkale
    Its an electric oven and gas hob by the way.
    #270564
    BobHope
    you need to think about this carefully,
    if the cable is getting hot and its 2.5 mm it has to be drawing more than 13 amps.
    i would avise you to contact an appliance engineer.
    Bob.
    #270565
    bodrumkale
    Thanks for your help
    #270566
    helo_75
    yep, but when th oven is on convection, its running TWO elements, top and bottom
    and you claim to be a spark?
    #270567
    bodrumkale
    helo_75 wrote:yep, but when th oven is on convection, its running TWO elements, top and bottom
    I was asking advice and it was greatly recieved, there was absolutely no need for the comment questioning my ”claim to be a spark”
    I am not a domestic appliance engineer and as the cooker has run without problem for over a year I assumed that there was something causing the overheating problem.
    I was asking the experts and hoping to get a solution.
    #270568
    helo_75
    im sorry if my comment offended, it wasnt meant to
    i see a lot of people in your predicament, and the question is always the same.. that being, why has it worked for over a year?
    well, that is a good question, and i just cant answer it i just know that it needs to be on a cooker point, as the total consumption can and does exceed 13 amps
    please accept my apology, i often state that messages can often be missread or missunderstood, depending how people percieve it, so im sorry if i offended
    i think youll find if you hard wire it to a proper cooker point, it will cure your problem, like a lot of people, u maybe looked a bit hard into the problem that your having, when the solution is relatively simple
    hope this has helped
    #270569
    bodrumkale
    Apology accepted, Already decided to install new circuit at the weekend , what you say makes good sense.
    Been putting off replacing her consumer unit for a while now so I think I will do the whole thing ( and get me part P mate to sign it off!!)
    #270570
    bodrumkale wrote:( and get me part P mate to sign it off!!)
    That’s a point, new circuits need a Part P spark to install it I believe? Do they also need 17th edition training? 😕
    #270571
    wsts
    Although I prefer it, its not a given that a 900mm single cavity multifunction oven has to have a cooker socket, for example a Stoves 900dfa can run from a 13amp supply, Stoves always recommend using a fused spur though for a better and more stable connection than a 3 pin plug, if the plug is getting red hot it may suggest that arching may be happening within the socket, the exact reason why Stoves recommend a spur.
    #270572
    dieselsteve
    These type of ovens use 13 amps and is spread over several elements
    most have 2 main elements at 2300w a turbo fan element at 2500w
    and a grill at 2400w
    oven should be hard wired not pluged
    ovens pron to burn out 1st connection block at point of cable attached to cooker also main cooker multi switch prone to burn out
    if main multi switch burn out some oven fuctions will work but will pull in more watts causing breaker tripping or cable over heating
    #270573
    The official position regarding 2.5 mm flex is that it is too big to go in a 13 amp plug.
