Elba PX906 S/N 10209 dual fuel range cooker
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Elba PX906 S/N 10209 dual fuel range cooker
  • #67048
    rocker
    I am fitted a new selector switch…but having a problem rewiring this switch…removed all the orginal wiring.. and rewiring from a diagram sent to me by connect..
    the diagram Ref Number 1131378..but there are a couple of cables left over that are not shown on diagram. so feel this may be the wrong diagram sent !!..can any one offer any help please !!!
    john
    #366075
    BobHope
    Re: Elba PX906 S/N 10209 dual fuel range cooker
    have you got the correct switch ?.
    does the appliance have a digital clock or a mechanical timer.
    Bob.
    #366076
    rocker
    Bob, mine has a digital clock!!. on the diagram shows the rotisserie switch close to the clock, but on mine the rotisserie is far away and opposite side of clock !!
    john
    #366077
    BobHope
    is it a multi function oven with top, bottom and fan element with a cooling fan, sorry for all the questions
    Bob
    #366078
    rocker
    yes that is correct, (dont worry ask any questions you want glad of your help).
    John
    #366079
    BobHope
    if you have part no. 1131378 i think it is the wrong one, i think that should be 1131114S.
    6 gas burner, single door electronic 6 button clock lefthand side, rotisserie switch far righthand side.
    Bob.
    #366080
    rocker
    Bob, it is a muli function oven, not sure about the cooling fan, dont remember seeing one, but could be wrong!!
    eveything you say is correct, except the clock has only three buttons.
    John
    #366081
    BobHope
    only three buttons on the outside but 6 on the timer the rest are hidden, i have a diagram for the 1131114S but not the part no. you have, if you want to give me an email address i will see if it will scan and i will forward it, you might be able to make the loom up out of what you have.
    bob.
    #366082
    BobHope
    you are right it does not have a cooling fan as its not on this diagram.
    Bob.
    #366083
    rocker
    Bob, Please sent diagram sure that will help me.
    many thanks for your help with this.
    John
    email..ableappliances@gmail.com
    #366084
    BobHope
    email on its way.
    Bob.
    #366085
    rocker
    Bob, received diagram thanks, sorry to keep on, but on my one, the negitive that has a direct feed to the clock, has a
    spade connector fitted in line,that feeds someting else, which I presume must go to selector !! as there is no other place to connect to..but not shown on diagram !!
    john
    #366086
    BobHope
    dont know what loom you have but there is a double connecter on the diagram i sent you, it comes from the mains terminal block to the thermostat then to the clock then to the oven fan motor and then off to the oven light.
    Bob.
    #366087
    rocker
    Bob, thanks for reply I am a bit lost myself with this one. re- the diagram / the neg grey cable that feeds the clock, there is a spade connector about 4 inches from clock..(appears to fit to selector) but can see that on diagram
    john.
