ElbaKenwood CK410 LH Oven Base Element
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ElbaKenwood CK410 LH Oven Base Element
  • #25516
    cookerfit
    Need to change the bottom element on one of these and there looks to be an easy way and a hard way!
    Can anyone advise the easy way as not done one of these before
    Thanks in advance
    Cookerfit
    #206192
    Kirk
    Re: ElbaKenwood CK410 LH Oven Base Element
    Not the easiest element to change. Take of back panel off.
    Above element 2 self tapping srews remove.
    Then go round front go into storage drawer lever panel below oven from the rear down then you get acess to the element which is easy to change.
    Difficult part is getting the cover back up and lined with the 2 self tappers.
    After you have done one you look forward to the next. Especially if like my last one thick in grease and muck.
    Kirk
    #206193
    cookerfit
    Thanks Kirk – I’ll look forward to it and leave it to last job so I’m not stinking of grease all day
    Cookerfit
