Elecrolux ESL6115 – Not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Elecrolux ESL6115 – Not draining
  • #36489
    welshrob1974
    Dishwasher is not draining – have removed filters and cleaned – removed drain pipe and it will drain into a bucket when pipe low enough – so its clear – it did restart and water ran straight out down the drain – therefore I take it the drain pump is u/s – what do you think and is it relatively easy to change? See they are about £25 on the interweb
    Have tried to start it again and after a couple of minutees I’m getting an audible alrm – 2 beeps and the selected program led is flashing??
    Any help please???
    Rob :rolls:
    #251193
    aqualectric
    Re: Elecrolux ESL6115 – Not draining
    Before you order anything………:wink:
    Take the pump off and check it’s not jammed with anything. Fragments of glass, bone and pips can stop the pump giving the impression of failure. If the pump is clear, then it is probably U/S.
    Power off before any inspection!! :plug:
    Steve.
    #251194
    welshrob1974
    Cheers Steve,
    Turns out it was 1 ” long stem from a rose or something stuck in the impellor – so wifey is going round ASDA now to get the beers in!!
