Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Electolux ER7620C Larder Fridge Ice build up
- This topic has 14 replies, 4 voices, and was last updated 17 years, 4 months ago by
rmacal.
November 19, 2008 at 1:11 pm #41158
rmacal
ParticipantHi can anyone help please
Have ice / frost build up on back panel even when set at lowest. Can get very thick but only progresses about two thirds down panel.
No obvious problems with door seal. Compressor may be running a lot of the time but difficult to tell.
After I have defrosted it, if before it starts to ice excessively again, I turn the fridge off it defrosts quickly enough
I have been given various advice from – its definitley not the thermostat if fridge is cooling – to it must be the heater / or / heater timer
I would be grateful if any of you eperts out there can help. – thanksNovember 28, 2008 at 11:10 pm #268976cockney steve
ParticipantRe: Electolux ER7620C Larder Fridge Ice build up
you appear to have diagnosed your problem (it’s what I would have thought as well 😆 ) you need to find/meter the defrost heater (thin “tube” wrapped round the bottom of the evaporator? )
also the thermistor (if there is one) or perhaps it’s got a Stat connection. in which case it will only be able to switch on when the fridge is cold enough to switch the compressor “off” (otherwise the compressor and heater would be fighting each other! )
November 28, 2008 at 11:32 pm #268977helo_75
Participantits a larder fridge
no thermistors, or defrost heater, just stat
stats can cause this problem just as easily as not working at all
you could try a stat… further to that, your compressors running weak, and due to the fact that your evaporator only covers 2 thirds, the latter is more likely
November 29, 2008 at 3:46 pm #268978rmacal
Thanks for the response folks
If I try replacing the stat can you advise what type I need as I cant see my fridge listed on the Whitegoods site.
There is a universal stat that states is a “K59 type universal thermostat to fit auto defrost fridges” Is this the type I am looking for?
In case its not the stat thats at fault I wouldn’t want to have to go to the expense of going to Electrolux for a part unless I had to
Thanks again for your helpNovember 29, 2008 at 6:37 pm #268979cockney steve
Now the proper engineers have told you, you still need to BE METHODICAL
the stat will change over…..from “cooling” (compressor)…to “heating”…..probably a delay-timer and relay, to switch the heater on.
It’s most unlikely that it would immediately switch from cooling to heating (though the Chinese may try that one)
No matter….it can switch as often as it likes…if the heater’s U/S it isn’t going to defrost! so, you need to check the heater, then check the circuit and all components that operate in the defrost circuit.
Freeze-spray is available from Maplin and is handy for testing thermostats.
taking a stab in the dark is a waste of money…..sure, you’ll eventually find the fault, but the idea of coming to this site is to save money and help the environment.
November 29, 2008 at 6:45 pm #268980helo_75
Participantits a larder fridge, it doesnt have heater, doesnt need one
November 29, 2008 at 6:59 pm #268981cockney steve
DUH! sorry, 😳 😳 :rolls: a senior moment for sure….what part of LARDER FRIDGE didn’t I see, in the title.
*slinks away*
November 29, 2008 at 7:07 pm #268982helo_75
Participantlol, s’ok mate, i do it many a time
December 7, 2008 at 9:59 am #268983rmacal
Thanks again for the responses
Seems to be narrowed down to the stat – any thoughts on which type / specific stat I should get?December 7, 2008 at 10:18 am #268984helo_75
Participantyes, can u supply the pnc number? its on the ratings plate, behind one of the salad bins… usually starts with a 9…….
December 7, 2008 at 10:58 am #268985admin
KeymasterRe: Electolux ER7620C Larder Fridge Ice build up
When you fully defrost the fridge,Do it for 24 hours with the door left open.
Then press the back wall with your fingers,Does it feel spongy ?if it does then there may well be a air gap between the liner and evaperator.Bryan
December 7, 2008 at 2:25 pm #268986cockney steve
shirley…shouldn’t that be “a gap between the liner and the insulation?”
I thought the Evap. sat on spacers so that air could pass both sides, thus increasing thermal efficiency?
A delaminated insulation/liner bond would reduce both the gap and the insulation effectiveness.and i won’t call you” surely, “again 😆
December 7, 2008 at 2:33 pm #268987admin
Hi Steve
Where the fridge is a wet wall the evaperator is bonded to the liner and the insulation is behind the evaperator.
Bryan
December 7, 2008 at 4:22 pm #268988cockney steve
Hi, Bryan-interesting stuff!
What’s the “advantage” (or is there a REAL benifit from the “wet wall” concept?….per my previous post, ~50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the surface-area is not going to be doing much(unless the absorbtion surface is heavily-finned,in which case there is increased manufacturing cost though that may be marginally offset by the smaller evap needed as a consequence of the “gearing -up”…..am I being smplistic, or am I really missing something?
December 17, 2008 at 9:40 am #268989rmacal
helo_75
Thanks for your informed input
Sorry took so long to get back but even once found where the number was I couldn’e read it with the small size and where it was located so had to wait for someone with better eyes to read it for me.
PNC 9238/2600 -
