Re: Electra AWM 1100A – Smelly repeating water !!
Paulusfirst wrote:…it’s a ‘w’ shaped thing…
Errr… Don’t know what that is!
It’s taking a week for this water to appear? A lot of water?
Basically the water is either coming down the drain from the sink, or one of the valves on the machine isn’t shut properly, and a tiny amount of water is getting through.
You can eliminate the valves, by turning off the taps on the fill pipes and seeing if it’s still fills. But, do you have towait a week to check that?
The best option is check Repairs@ and see if there’s a local engineer to help you out 😉
If your going to check the valves, please unplug the machine before routing!
