I have to replace the bearings and while doing this a friend suggested replacing the brushes. Are these in a small housing at the end of the motor or can it be a 3 phase motor as there are no obvious brushes nor a ny clear armature windings
Do you know something about the Nuova Ibmei m2-16-158/AR 27?
It’s in my washing machine Markling ZMSV 809.
All of a sudden, the motor is not turning anymore, only the pump is running. Therefore I was also thinking about changing the brushes, but it seems there are none. Or I would have to detach the motor first.
Markling – Is that the brand name of the washing machine ?
I guess you’re not in the UK if it is 😉
Same as the Electra problem no doubt. The module will be at fault normally, these machines are made by Merloni in Italy, also trade as Servis in the UK.
