Electra C4510IE Dishwasher Error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Electra C4510IE Dishwasher Error
  • #100554
    Willow94
    Hi all,
    Have installed an integrated Electra C4510IE Dishwasher today but am having an issue.
    There are three wash types which are as follows:
    P1 – Eco wash
    P2 – Intensive 65 degree
    P3 – Super 50
    I can use the P3 cycle fine but when I try to use the P2 cycle the machine stops part way through the cycle and flashes up with an error message, the error message ‘possible fault’ in the user manual is a ‘water inlet failure’.
    It seems there is an issue with the water inlet but I don’t see how this could be seeing as the P3 works fine, if there was a water inlet issue surely none of the programmes would work?
    Has any experienced anything similar or can advise what I could do to fix this?
    Thanks for your help!
    #481065
    double check the inlet hose is not kinked and the tap is fully on
    Willow94
    electrofix wrote:double check the inlet hose is not kinked and the tap is fully on
    Thanks Dave, I will have another check.
    If there was a kink, would this not affect all of the cycles? As one of the cycles runs fine (50 minute wash)
    #481067
    fill depends on programme and water pressure at the time. some one could be using water down the road could reduce pressure
    it could be just coincidence that p2 failed
