Electra dishwasher control panel
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Electra dishwasher control panel
  • #103306
    Eddybaby
    The manual for my Electra dishwasher c1760se is useless as part of the control panel (not digital btw) isn’t shown anywhere. Can anyone help?
    #492580
    thos light do 2 jobs
    if you just set a programme and run it then its wash , rinse and dry
    if you select to delay the programme from starting you can delay it 3h 6h or 9h. normally so you can take advantage of cheaper power
    Eddybaby
    Thank you Dave…..those symbols are no where to be seen in the manual. I don’t suppose you know why it’s not drying?
    #492582
    is it getting hot ?
    what type of detergent are you using ?
    do you live in a hard water area ?
    Eddybaby
    Hi Dave. I think its getting hot …it steams my glasses up when I open it:D
    I’ve just started using Fairy Platinum Plus. According to Yorkshire Water the water moderately soft . Hope this helps
    TIA
    #492584
    check the programme your using
    some of the more eco programmes dont dry as well to save power
    Eddybaby
    I don’t use the eco programme for that reason. Any suggestions as to why it’s not drying? Thanks again.
    #492586
    as long as the water is hot and there is rinse aid it should dry
    some of the later dishwashers pop the door open to help drying without using energy and some have a fan to blow air in
    dont know what yours does as not enough info
    Eddybaby
    Ah could be rinse aid. I’ll top it up and see what happens next wash. Thanks again Dave
