electra dryer
  • #102092
    tash
    hi been to model TDC9112B tripping . short on thermostat-due to water coming from fan. they never empty it. new heater and stats fitted but now run couple of secs and the 3 hour and 9 hour lights flash and it cuts out. any help appreciated
    #487561
    that does not seem like a fault code
    tash
    thanks dave. well it looks like E05 by that chart. would they be solid or flashing or doesn’t it matter. cheers
    #487563
    all manuals and teat routines are on aswo
    but you will need the long serial no to get correct one as there are lots with same model
    are you sure parts are correct ?
    there are over 40 variants of this model
    tash
    00727109010218810076 is the serial no
    i already had the part in stock but only went by visual so maybe the ntc is the wrong value. i didn’t have a part number
    #487565
    they do look pretty universal
    since i assume you swopped element you can check old NTC against new one
    had a beko short an NTC out and it blew a resistor on the board so you could chack for that
    you can check continuity back to board
    tash
    will check. much appreciated Dave
    #487567
    tash
    faulty ntc sorted now thanks
