PCB module burnt, track damage, s/c components, dead, no display on control panel. Replaced PCB Module with a new module from connect.
Panel now lights up but unable to set a program, does the module require configuring?. Anyone know how to do this? Any help would be appreciated.
Often when the power module blows it takes out the display module as well. Careful attention to the state of the motor is advised as neither module self-destructs if you catch my drift? 😉
may just need config.. they are a total minefied tbh
i would check motor if poss.. we use to do servis direct and we fitted motor/module to nearly every w/m we were called to..
