electra gl2 (italy)
Home Forums Public Support Forums Spare Parts Help electra gl2 (italy)
  • #36629
    garn
    hi garn hear
    came across an electra GL2 MINT CONDITION TODAY
    52 YEARS OLD NEVER BROKEN DOWN
    WOULD YOU KNOW SOME PARTS NUMBERS OR MODEL?
    NEEDS BRUSHES & PUMP
    THANKS
    #251760
    Alex
    Re: electra gl2 (italy)
    Where did 50 odd years come from? If you give me the serial number, on a silver palate at the rear just below the tub breather pipe, I can date it to the month.
    Electra GL2 500 spin, was sold through the Electricity Boards 1974 to 1977, made by Zanussi along with the 300 spin GL1. The bearings on those was bigger than the present day ones on the 1,000 spin machine.
    Prior to that was the L1 & L2 1972 to Oct 1794. These were eventually replaced by the Hoover Electra A3E02 range. No Electra ones were the DL range.
    How come it needs brushes is beyond me, they used an induction motor?
    Zanussi only entered the uk in the mid 60’s, but was badged Imperial.
    Alex
    #251761
    garn
    Alex wrote:Where did 50 odd years come from? If you give me the serial number, on a silver palate at the rear just below the tub breather pipe, I can date it to the month.
    Alex
    thanks alex
    a pensioner saw my van this morning
    her husband bought it many years he worked for the old electricity board high street shops.
    the machine was running at the time
    couldent withdraw it.
    symtoms are clothes are damp on the spin
    #251762
    aqualectric
    Sounds like a blocked filter to me….. 😉 It may be difficult to pull out, but it is possible with patience. Electra GL2 , Zanussi DL / SL series and Zoppas machines were ultra reliable, durable, simple and cheap to fix – everything the modern day manufacturers have lost sight of.
    IIRC, pump, door gasket, inlet valves and door handle are still available today.
    Steve.
    #251763
    Proper rubber drain hose collapsing will do exactly this. 480rpm spin – they’re never exactly going to be dry, I’m afraid.
    Alex
    Capacitor used to play up, but then you would get a poor wash, and failure to ramp into spin. Think it was 16mf
    Also watch for overfilling, then the water would not evacuate enough before spin, and the drum would send the water around in a vortex, and would not drain properly. Water level on Cottons 1″ up the front plastic door inner, on delicates halfway between the lip of the door seal and the centre of the door handle.
    Alex
    #251765
    garn
    Alex wrote:Capacitor used to play up, but then you would get a poor wash, and failure to ramp into spin. Think it was 16mf
    Alex
    ok thanks for the info
    il check it out
