electra tumble dryer
  • #102497
    tash
    Model TDC700s
    ser 0072722
    im trying to get the front drum seal but can’t seem to find any info on this model. it looks like a beko condenser dryer. thanks
    #489174
    are you certain of model
    can find TDC7100S which is built by vestel
    if it is vestel should have a long serial no
    tash
    yes sorry Dave it is TDC7100s
    007272240102305
    #489176
    ok aswo have stock £2.78
    you have to use all the numbers to get correct machine
    first put in model and look at the other numbers listed and you have to modify serial to suit. in this case first half of number changed to
    10727224
    by missing off the 00 and adding 10
    the second half of the number becomes
    5701023050
    after adding 57 on the beginning
    you should then get all service manuals and parts this for this model
    tash
    much appreciate you
