Electra washer w1449cf2w
  • #102938
    tash
    Hi this washer flashes spin and end lights. Same as when the door is open. Bypassed door sw to test still the same. Checked motor heater valves all ok. Anyone know please? Thanks
    #491146
    Hollytree_Technical
    I would need the 20 digit serial number to make sure that I was in the right service manual but picking one at random would suggest that it is:
    E06 – Motor Failure – 1 (Tachometer Open-Short circuit or Motor Connector Is Disconnected).
    Jem
    #491147
    tash
    Ok thank you
    #491148
    if you have access to aswo
    service manuals will be on there
    tash
    I do Dave but never seem to be able to find them 🙁
    #491150
    ok first go to aswo and put in model and you get this
    then look at your serial no
    you will find the start of the serial number includes the number under the model 10706963 or similar you have to alter or add the first digits
    add this to your search number so you then have
    W1449CF2W 107006963 in your search box
    now onto the rest of the number
    from above the numbers start 53 you have to add this to your number
    so your search box becomes
    W1449CF2W 107006963 5300586946
    this should get you to one model
    the manual is in the documents attached to the model along with parts breakdowns etc
    its not hard doing this once you get the method
    tash
    Ok thanks I need to spend more time doing it
