electra wd 1100a
  • #8667
    piggypoo
    lucky me, picked up theis second hand machine but no manual and canny get the spin or dryer part to work…any info lurking around?
    #129889
    Re: electra wd 1100a
    piggypoo wrote:lucky me
    You are indeed ❗ ………….. what exactly doesn’t work (does it pump? will the drum turn? does it fill? )…., please explain a little more? 😀
    piggypoo
    fills up and washes but after 2 hrs from cycle A, the clothes are still soaked and can’t figure out how to spin. Also can’t figure out how to do dry. I don’t even know if it’s a proper drier? So i guess it may be working but without instrutions, it’s like trying to open a safe.
    #129891
    piggypoo wrote: it’s like trying to open a safe.
    Indeed so, but you didn’t answer all my questions…….Does it pump?
    If not you may like to check the pump/drain filter 😀
    pump?..i’m not sure what you mean.. it pumps the water out after the cycle. How do i check pump/drain filter. I bought 2 new hot/cold pipes with little filters on the end..
    #129893
    just to verify..yes drum turns etc.. but i could not detect a proper spin cycle, just normal wash rotation.
    #129894
    Anonymous wrote:pump?..i’m not sure what you mean..
    Surely you have checked the pump? (Behind the trap door bottom R/Hand side at the front!!!!)
