I have a Leisure AL6CDW electric oven. Everything on the oven is working save for the time display and the oven not heating up.
The other day the electric in the house tripped. The oven was in use at the time, but I’m unsure as to what caused the trip. Switch it back on at the fuse box and since then oven just won’t warm up.
The oven light works. The fan moves. The grill and hobs heat up. I’ve had a look at the terminal block front and back and can’t see anything apparent like a loose wire or anything silly 😀
Any ideas?
