Electric Fan oven not heating, but fan and grill work
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Electric Fan oven not heating, but fan and grill work
  • #85089
    gavlaruk
    Hi, I’m guessing my main oven heating element is faulty as the grill, fan, lights etc work fine. There was also a burny smell before it failed to heat.
    But im unable to find out the model of this oven, and not sure which part is the bit i need to take out? never done this before… i’ve provided a link to some photos so hopefully someone could help me? Thanks in advance!
    https://dl.dropboxusercontent.com/u/110 … 075556.jpg
    https://dl.dropboxusercontent.com/u/110 … 075625.jpg
    #427690
    Re: Electric Fan oven not heating, but fan and grill work
    It’ll no doubt be the fan element that you can get to from inside usually at the back.
    Without a make and model it’s nigh on impossible to tell you any more or to identify the element either.
    gavlaruk
    Ok thanks, so take the fan bit will have the heating element attached to it?
    #427692
    On the inside the element is mounted to sit around the fan.
    gavlaruk
    Ok cool many thanks!
    #427694
    gavlaruk
    kwatt wrote:On the inside the element is mounted to sit around the fan.
    I got it out and looks like this but cant find make and model of the cooker 🙁
    heres the pic of the heating element if it helps identify?
    https://dl.dropboxusercontent.com/u/110 … 113352.jpg
    thanks
    #427695
    gavlaruk wrote:heres the pic of the heating element if it helps identify?
    Sadly no. In the absence of the make and model you can only identify by checking the wattage stamped on the fixing bracket and measure the element as per the instructions below….
    #427696
    gavlaruk
    Cool ok… many thanks for you help, i’l get the tape measure out 🙂 2100w
