Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Electric oven under counter (with induction Hob on top)
- This topic has 4 replies, 2 voices, and was last updated 17 years, 1 month ago by
yoghurt.
February 17, 2009 at 2:34 pm #43545
yoghurt
ParticipantHello
Our current De Dietrich single electric oven which is built in under the worktop (and a De Dietrich Induction hob on top) is on its last legs. (element repaired several times, control knobs lasting less than a year before snapping etc)
Had a quick look at the forums and Neff seems a good make-we would also like a double oven.
However am I going to find it difficult finding a double oven to fit underneath which gives enough ventilation space for the hob? Any recommendations would be great
many thanks
Yoghurt
February 17, 2009 at 4:28 pm #277632don
ModeratorRe: Electric oven under counter (with induction Hob on top)
Hi yoghurt
All the tech spec I have come across and the conversations I have had with manufacturers so far say ” only a single oven can be installed under a induction hob to ensure adequate ventilation”.
However someone else may know different 😉
Another way of achieving a double oven may be to have a single oven as now and add a combination microwave which would then give the second fan oven.HTH
Don
February 17, 2009 at 5:37 pm #277633yoghurt
ParticipantRe: Electric oven under counter (with induction Hob on top)
Many thanks Don
That sounds a great idea having a combi microwave
(just means more research now on which ones!).
Our existing Panasonic microwave/grill is over 10 years old and still going strong-are they still a good make for Combi microwaves? Also what sort of ventilation do they need as our current microwave is in an under counter cupboard but with quite a bit of clearance around it.
Will look out for single ovens made by Neff and Bosch which appear to be good makes (unless someone has managed a double oven underneath an induction hob)
Cheers
Yoghurt
February 18, 2009 at 8:09 am #277634don
yoghurt wrote:
(just means more research now on which ones!).The Sharp combis are about the best IMO.
yoghurt wrote:
Also what sort of ventilation do they need as our current microwave is in an under counter cupboard but with quite a bit of clearance around it.As long as there is an airflow around it then that should be fine.
Don
February 24, 2009 at 5:53 pm #277635yoghurt
Thanks Don
