Electrical burning fault with Indesit WIA 101
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Electrical burning fault with Indesit WIA 101
  • #65246
    planze2
    My indesit WIA 101 washing machine is only a couple of years old.
    I have just smelt burning so I switched it off.
    The cable felt warm so I disconnected it from the socket and opened the lid.
    I unplugged the connection at the top inside of the machine where the cable runs into a plug. I could see burning around one of the connecting pins and surrounding plastic.
    Doesn’t sound good but just wondered if it’s likely that the machine is a write-off or is easily fixable.
    any advice appreciated
    #359817
    Re: Electrical burning fault with Indesit WIA 101
    It just needs a new mains cable and suppressor assembly, part number C00111940. Around £23 + vat.
    Mind you two years is quite good for an Indesit. :rolls:
    #359818
    planze2
    thanks for that.
    #359819
    planze2
    Hi, Just trying to find the part online but not easy.
    Do you know best place to purchase?
    The part seemed to be a sealed unit which comes with the cable attached.
    To make sure, I’ve attached pictures of it.
    many thanks
    #359820
    don
    Iadom’s part number of C00111940 is correct for your pictures.
    You can order one from the UKW shop. An email to spares@ukwhitegoods.co.uk should get the ball rolling.
    HTH 🙂
    Don
    #359821
    planze2
    Many thanks
    #359822
    You may need to repair the wiring connections that plug into the top of the suppressor.
    The original ones are fearfully weak. :rolls:
