Electrolux 1200 – Aqualux 1200 EW1200
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Electrolux 1200 – Aqualux 1200 EW1200
  • #51980
    bjstanbridge
    Firstly I have to say I am not really a practical man, but my daughter’s Electrolux 1200 machine is not working properly.
    When you switch it on it starts to fill then after a few seconds the dial starts to click around goes through all the programmes and finishes.
    I assume that it must be a timer or board fault.
    Is it easy to replace these parts yourself.
    As its built into the kitchen unit I suppose that you have to somehow slid it out first to be able to get the new parts in.
    Any idea what the costs of the parts might be? as the the machine has been very lightly used even thou its 4 or 5 years old now but the apartment was empty for nearly 3 years. Would it be better to scrap the machine and get a new one?
    Money is very tight at the moment thats why I am considering the repairs myself
    Thanks for you help
    #310184
    Re: Electrolux 1200 – Aqualux 1200 EW1200
    Not the wisest assumption to make. 😉
    The control boards are serious money on these and the fault may be nothing at all to do with the board.
    A qualified local independent engineer should be able to run the diagnostics test routine to identify the source of the problem.
    Given your words in your opening sentence I would strongly advise that you go down that route.
    It would need removing from under the units for almost all repairs, also these are not the easiest machine to work on.
    A decent machine, you should have it looked at before discarding it.
    #310185
    bjstanbridge
    Thank you for your reply.
    I have called one company in Leicester and he says over the phone its going to be the board £180 better off getting a new machine!!
    Another company Repair Care who you book over the internet £116 but that includes all your
    Call Out & Evaluation
    All Parts & Labour
    Professional Safety Check
    All Work Guaranteed
    are they going to say right, looked at the machine thats £116 need to order this part that part and thats another £116 because if the boards are £180 they can be doing it for £116 can they there must be a catch somewhere.
    #310186
    Have you tried HERE
    #310187
    Beta
    In responce to the moderator, unfortunately the model mentioned does not have a diagnostics routine.
    It does have an older form of mechanical timer with attached module.
    To the poster, have you tried cleaning the filter ?
    #310188
    Beta wrote:In responce to the moderator, unfortunately the model mentioned does not have a diagnostics routine.
    😳 Twas a busy day, should have asked for a Pnc number..
    Worth checking the Motor brushes
