Electrolux 43010 Dishwaser – Water Leak
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Electrolux 43010 Dishwaser – Water Leak
  • #99385
    ddavid25
    Electrolux 43010 – Water Leak
    Hello,
    I have an Electrolux 43010 dishwasher which was installed when my home was created in 2014. We moved into the home last year and have had no issues until now.
    When I activate a run I noticed water splashing out the bottom which it hasn’t done before. The only change we have made since the last time we run it, was today in which we added some “Rinse Aid” which we haven’t done before. I’ve seen a few people say a overspill could cause foam build up forcing the water out the bottom. Although the splashing is happening straight away, whereas rinse aid is used at the end. I have since wiped down the inside of the machine and drained it. I am still getting the issue however.
    I have taken the front panel off and can see the seal at the bottom of the machine which has two gaps on each side, which I presume is for water movement. The right side is fine with no water splashing out, however the left side has water splash out at force every few seconds.
    I have taken this bottom seal off and cant see any damage, although it is 7 years old now.
    Ive also taken a video which is below,
    Any advice around a solution for this would be greatly appreciated. (I do find its strange that its only done this since adding rinse aid)
    https://drive.google.com/file/d/1HzFKBnKLTYQpam-HOc_7lCvIPgrM9sX3/view?usp=sharing
    #476130
    is the bottom seal ok ?
    what the correct model no ?
    have you checked wash bars for blocked jets etc
    ddavid25
    electrofix wrote:is the bottom seal ok ?
    Hello thanks for your reply,
    Yes I have checked the seal and it looks fine,
    The model is: 43010
    I have checked the wash bars. All looked fine except the bottom bar has a very small slit where the two pieces of plastic meet on the corner. Mabey this is causing too much pressure, forcing the water into the corner?
    #476132
    that model is not correct
    find the pnc number on the model label
