Electrolux 727043 Glasswasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux 727043 Glasswasher
  • #64049
    euro
    Had a quick look at this today, fault reported was is wasnt washing properly. The machine fills up ok, heats and starts washing but then the drain pump comes on and stays on all the time. Anyone got some ideas what the problem might be
    Andy
    #355877
    euro
    Re: Electrolux 727043 Glasswasher
    Model number is WT21
    #355878
    euro
    Anyone with suggestions on this please??
    #355879
    spanner51
    I am not sure about your one, but as with others I have seen, the drain runs while the machine washes and rinses. As long as the stand pipe is in place this is normal. HTH
    #355880
    euro
    Whats the reason for the drain pump running on them when its washing ????
    #355881
    hf
    ones i have seen drain some water on the rinse as clean rinse water is being added,, but if it continues to drain check the second level pressure switch is dropping back..
    #355882
    euro
    Replaced the pressure switch and it runs fine now
