Electrolux/aeg lava mat turbo 16830
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Electrolux/aeg lava mat turbo 16830
  • #65539
    Cupoftea
    It doesn’t dry anymore.
    It’s about 5 yrs old
    It washes ok.
    The guy said it would cost about £190 to fix, the part is quite expensive.
    Should we get a new machine completely or get this old one fixed???
    #360910
    Re: Electrolux/aeg lava mat turbo 16830
    Cupoftea wrote:The guy said it would cost about £190 to fix, the part is quite expensive.
    What exactly is wrong with it then?
    Cupoftea wrote:Should we get a new machine completely or get this old one fixed???
    Depends on the answer to my first question and if you can afford to replace of repair anyway?
    #360911
    How often do you actually need to use the drier ?.
    If you have space then get a separate drier which are more efficient to operate than a wash drier.
    Bryan
    #360912
    Cupoftea
    The engineersaid it ws the circuit board had gone… But I’ve read some replies other place and it sound as though we need to check a wire..
    #360913
    Cupoftea
    It works for about a minute or two and then outs itself onto pause.
    Or shows error e10
    #360914
    Cupoftea wrote:It works for about a minute or two and then outs itself onto pause.
    Or shows error e10
    The problem is simple and relatively cheap to fix…IT DOES NOT NEED A CIRCUIT BOARD…The fault (E10) refers to the water inlet valve being at fault. A very common fault and easy to fix….I suggest you get someone else in to sort it and advise them of my diagnosis. To find a good engineer in your area you only need to check out THIS LINK 😀
