Re: Electrolux built in oven overheating always on max!? (HE
let make sure
you fitted a new stat that is behind the nkob on the front of the cooker. you fitted it as one unit and did not take it apart to fit it in any way
the new stat and the old stat were the same make and model
the tech info shows 4 poss stats and although term 1 never moves the other 2 swop. so that may be your problem
