Electrolux cooker hood
Home Forums Public Support Forums Help And Support Other Appliances Electrolux cooker hood
  • #91251
    Wontgiveup
    My cooker hood starts ok then slows down to a humming sound after 20 seconds or so. A new motor and capacitor failed to correct the problem. The PCB board has also been replaced but could this cause the problem? Otherwise I can’t see what’s left to fix! Any thoughts 😥
    #447562
    Re: Electrolux cooker hood
    the model and production number would help us to look up tech info
    Wontgiveup
    It’s an Electrolux CH90X hood PNC 942492219. The control panel is about 18 months old. A new motor with capacitor was tried only 2 weeks ago but didn’t correct the fault.
    Regards
    #447564
    when you say the control panel I assume you mean the operaters buttons if yes then your fault is likely to be the electronic control board itself but also say in first post you have replaced that
    since there is only about 4 parts in it cant see what else you could change. my bet is still main pcb problem
