Help please.Elux d/w model esl6115 pnc 911939201/02.
Problem is as follows:will not start was the original problem. I srolled in to the kitchen closed the door and the machine started! Cancelled the programme it was on, selected a quicker wash, closed the door and the machine pumped out, refilled, washed, heated pumped out-went right to the end of the prog went bleep bleep at end. Thought what a stroke of luck! Opened the door, went and turned off the on/off button and then the trip went off. so I had a look at the pcb-nothing, no blown marks and looks ok but every time tried to swt on the trip went off.I can only think that the pcb is at fault based on this or perhaps the wiring loom, I know the other component parts all work since my test proved it. To double check I tested the element and that is still ok. Situation is that the machine refuses to even trip out now, no lights no nothing zippo although there is power to the board. The suppressor looks ok too! Any ideas please?
