Electrolux Dishwasher esl6115 Water not heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Electrolux Dishwasher esl6115 Water not heating
  • #36452
    barneey
    Hi All,
    My Electrolux ESL 6115 dishwasher (PNC911939201/02) (SN62730345) (PN143861) has developed a fault. The water is not being heated and remains cold throughout any chosen cycle. Everything else works ok and it doesnt trip the electric circuit. It just washes with cold water every time.
    Would this be a faulty element or a temparture sensing unit? I am mechanically minded but have never replaced a part on a dishwasher but am willing and want to give it a go, if not only to save but to learn at the same time.
    So if anyone could give any guidance on the likely problem & the easiest way to get the appropriate part out (ie remove dishwasher unscrew back panel OR keep dishwasher insitu and remove internal panel etc) I would be very gratefull.
    Many Thanks
    Clive
    #251039
    Re: Electrolux Dishwasher esl6115 Water not heating
    The most common cause of this fault is a relay failure on the PCB.
    Lots of info on this if you do a search. 😉
    Enter, Zanussi AND dishwasher AND heating, in exactly that format in the search facility for this forum and you will find all the information you need.
    barneey
    Many thanks for you guidance iadom, just had a read through the posts, off to find my soldering iron.
    #251041
    barneey
    Hi Just to say thanks again I followed the post http://www.ukwhitegoods.co.uk/modules.p … er&start=0 and resoldered the relay and everything for the time being is working fine, I will of course be back to buy a new PCB if the need arises.
