Starts up fills then aborts/drains out as if anti flood has operated.
End cycle flashes/beeps once intermitently.
There was water in bottom tray which removed.
Still the same.
The fault code appears to be a water inlet problem.
But the machine fills so far then aborts?
I have seen this sort of problem caused by overfilling. They made a pressure switch conversation kit to stop them blocking up which is an extra pressure chamber. It sits in the sump and is held in place by one of the sump screws. If your machine doesn’t have this then it probably needs one fitting. If it has it check it for blockages.
Good lick
