model 911434314/09 model esl8510r0
orig issue i50 error wash pump
fitted new one – worked for about 30mins – i50 showed up again
i suspect it may be something to do with the new pump – when i opened the box the impeller part was loose – so i pushed it back into housing, these new wash pumps are like drain pumps where you can pull the impeller out .
im not sure if these impellers should lock into place?
hope this makes sense – if you have done one of these motors you will hopefully know what i mean
to recap – does the impeller need to pushed back into housing so it locks in ?
