Electrolux Dishwasher Not Filling Fault Code.10
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Electrolux Dishwasher Not Filling Fault Code.10
  • #91287
    tombolton82
    Don’t know if anyone can help me but I’m struggling to figure out why our dishwasher isn’t filling up.
    Its an Electrolux ESF6510LLW 91151607403.
    The water does go into the dishwasher but very slowly so it times out and beeps with error code .10 I’ve found the error code in the manual and it says that there is no water getting into the machine. Its been like it for a while and we just chuck a jug of water in it each time it beeps and then its fine.
    From looking online everyone seems to change the solenoid when it doesn’t let the water in. Our dishwasher has a water softner unit with the solenoid attached so i’ve changed that and it’s exactly the same.
    The only other thing that I can think of is the hose but I’m not sure and I don’t want to spend another £50 on a hose if its not that, I’d rather just replace the dishwasher.
    Any help would be really appreciated!!
    Tom
    #447652
    Re: Electrolux Dishwasher Not Filling Fault Code.10
    the inlet hose contains the inlet valve at the end
    part numbers 1560631044 which will change to 8072506044 when stocks run out
    before you order it check
    1 the hose filter at the end
    2 the water flow from your tap
    ask the site shop for a price as i cant see it listed
    https://shop.ukwhitegoods.co.uk/
