Hi Gents
esl6310 911939233 need help as there was no heat on machine tested heater and cable all ok what happens is when 30 min wash asked for the machine empties then stop for 2 mins or so then fills and washes dispensor opens no L or N to heater live comes from P/Switch neutral from board suspect P/Switch fault shorted P/Switch to send live to heater but still no N to element FITTED NEW MODULE filled up after drianing no 2 min delay washed dispensor opened but no heat agian am i missing somthing readings on thermistor ok
cheers alro
Check the module/programmer, take it out and check the connections to the big black relay on the board! probably blown. Repair , replace relay or replace borad!
