Hello,
My old dryer served me great for many years, and I like to keep it.
recently, error E50 appears some time after starting. When I start it again, the error appears again after some time. after 5-6 times like that, the dryer complete the drying successfully.
The technician ans for a lot of money to come and fix it, like half the price of a new machine. I like to fix it myself. Can you please advice what is the procedure to follow?
thanks !
EDC77150 Type P542666 Prod. No. 916 096 069 0 1
I already disassembled the control board. The label on the board housing is 9160696069(01) …. Firmware TBB10107
yes, I know. is there a way to check if it is the motor it self or the board? since the failure is not permanent…
is there something I can fix rather than replace?
thanks
A possibility could be the motor reversing relay on the PCB. I had one in the past that was intermittent whereby sometimes the motor would just stop instead of changing direction
