Electrolux D’W ESL614 heater on at wrong time
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux D’W ESL614 heater on at wrong time
  • #33596
    Seamy
    Got a call from a customer who says heater seems to be on before machine fills with water, she wanted to put some extra stuff in & when she opened the door the machine was at beginning of cycle, pumping out & heater was on.
    I suspected timer fault & have to go out to inspect it later in week.
    Anything else cause this?
    #239297
    aqualectric
    Re: Electrolux D’W ESL614 heater on at wrong time
    Most likely the ‘pumping’ noises she heard are the wash motor spinning with no water in it. That would also explain why the heater was on with no water in the tank.
    This is the old style sump with the “blue” siphon tubes that block up. First remove the large filter then the cap that covers the siphons. Clean them out and pour some water down the holes they come out of to dislodge any muck. Then refit the siphons and cap. From underneath the machine, remove the ‘U’ shaped clear hose under the siphon pot and clean. Also clean the nozzles on the sump. Refit the hose and pull off the pressure switch hose and the valve safety shut off hose at the sump end. Blow down the hoses to test the pressure switch and to dislodge the locked off valve. Refit the hoses and test machine.
    If the valve is still locked out (hums but no water) a sharp tap on the inlet hose ferrule at the back of the machine with a small hammer will free it off. (do this with the valve humming). Everything should now function.
    Hope that helps,
    Steve.
