Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › electrolux ekt 6045x no elements working
- This topic has 17 replies, 5 voices, and was last updated 11 years, 5 months ago by
slyp98.
October 21, 2014 at 6:19 pm #82727
slyp98
ParticipantProb here grill and fan oven not working touch control top is working fine , i have a live bit no neutral coming from the main pcb anyone have any experience of this the pcb is 170 quid , id like to find out what’s stopping it sending a neutral
October 23, 2014 at 9:19 pm #420668iadom
ModeratorRe: electrolux ekt 6045x no elements working
And one last BUMP. 😆
November 20, 2014 at 1:16 pm #420669slyp98
ParticipantRe: electrolux ekt 6045x no elements working
Bump again
November 20, 2014 at 5:18 pm #420670Hollytree_Technical
I don’t know the unit so am working off of the diagrams here.
Do you have a neutral to BR7 on the PCB?
If the unit had reversed polarity to the diagram I would suggest a relay failure to BR1/BR2 or blown cut out.
From the diagram it appears to be a double oven, does either oven work, what about motors and lights?
Can you post a decent quality photo of each side of the PCB (I would like to be able to read the writing) in which case I may be able to give you a couple more pointers.
Jem
November 20, 2014 at 11:03 pm #420671slyp98
Hey Jem, i don’t have pcb pics sorry the interface display lights up and all the functions can be selected , grill, top oven ,defrost, main oven etc , but the top oven and grill will not start to work nothing it looks like its in according to the interface but no motors or elements are being powered up, the main oven works fine as do the hob plates , i cant be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} but it seems to lead back to the main pcb power board there are 2 boards near the 220v incoming supply positioned on the rear of the main oven cavity i can find a live going out but no neutral, there are also 3 hob area boards but i think its safe to say that if the main oven control is ok then the top oven /grill func is ok too its all touch control stuff
November 20, 2014 at 11:39 pm #420672Hollytree_Technical
According to the diagrams the hobs are effectively a separate appliance with their own control and power PCBs which means that we can ignore them.
I take if from what you are saying that the lower oven works fine and that it is just the top oven that has failed.
The elements share a common live connection to each other which comes through a 180C thermal cut out from BF6 on the PCB (this is controlled by one relay).
The neutrals for the elements are individually switched by relays on the PCB, the neutral connection to the PCB is fed in on BF3 (a different connection to the one for the main oven).
Have you checked the PCB for dry joints? It would be strange for 3 relays to fail at once.
If you have checked that the wiring is as stated above and the PCB joints look good then I would double check the sensor.
The top oven sensor is the same type as the one for the main oven so it may be worth quickly swapping them to confirm that it is not a sensor issue.
If none of the above works then I can’t help you any further without photos as that is as deep as the diagrams go.
Jem
November 21, 2014 at 12:44 am #420673electrofix
this is a long shot but does this oven have a demo mode?
November 21, 2014 at 9:40 am #420674slyp98
Thanks Jem , i will go back and recheck the pcb and the sensor i take it its a ptc do you know values and ill take a few photos of the main board
November 21, 2014 at 9:42 am #420675slyp98
electrofix wrote:this is a long shot but does this oven have a demo mode?
dunno im sure it does Dave , also read somewhere it could be locked in timer mode but im sure the times would have to be set at some stageNovember 27, 2014 at 7:32 pm #420676slyp98
Hollytree_Technical wrote:According to the diagrams the hobs are effectively a separate appliance with their own control and power PCBs which means that we can ignore them.
Jem Hi Jem , went annd took a few pics today , on closer inspection none of the ovens work top or bottom ,hob is working fine ,i checked board over no sign of anything wrong , so has to be control board i have a few pics ill try upload em here https://onedrive.live.com/?cid=C3D31F04DC83B722&id=C3D31F04DC83B722{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}212950&parQt=allmyphotos&parId=root&v=3https://onedrive.live.com/?cid=C3D31F04DC83B722&id=C3D31F04DC83B722{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}212945&parQt=allmyphotos&parId=root&v=3
November 27, 2014 at 9:39 pm #420677Hollytree_Technical
I can’t access the photos.
Jem
November 27, 2014 at 11:19 pm #420678slyp98
How do i upload them directly from my oc anyone know
November 28, 2014 at 7:24 am #420679Martin
slyp98 wrote:How do i upload them directly from my oc anyone know
Huh?
Using your browser then click on ‘upload attachment’
Using Tapatalk click on ‘Photo Album’Simples! 😀
November 28, 2014 at 9:00 am #420680slyp98
Don’t get it i installed tapatalk on my windows phone and i have the forum in the menu list but when i hit browse below nothing happens help
November 28, 2014 at 1:05 pm #420681Martin
slyp98 wrote:Don’t get it i installed tapatalk on my windows phone and i have the forum in the menu list but when i hit browse below nothing happens help
I have enough trouble helping you fix appliances without adding your computer issues to my list, sorry. 🙁
