Re: electrolux elements
more or less the same, would be better to try with real part numbers, the difference is, and Connect don’t seem to realise this as they sometimes supply either as an alternative, is the length of the tags behind the bracket. On certain ovens, if the tags are too long they stick right into the heart of the terminal block with disastrous consequences and I guess you will know how I found that one out. For this reason I only carry the short tag version. (311 77 04-00/1)as these seem to fit all 2.5kw applications.
