Electrolux ENB 40400X Freezer ok, Fridge not working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Electrolux ENB 40400X Freezer ok, Fridge not working
  • #63118
    ent
    I have a Electrolux ENB 40400X. All of a sudden the fridge is not chilling. The freezer still works ok. The light in the fridge is still ok. I’ve gone through the manual and try to set the temperature on the control panel but it does not want to SET. the display shows the temperature of the fridge as 17c so it knows the temperature, but it just does not allow me to set it to anything. Any help would be most grateful.
    #352639
    Applianceman2010
    Re: Electrolux ENB 40400X Freezer ok, Fridge not working
    Assuming it is a blown air type (cold air from the freezer) i expect the channel that conveys the air is blocked with ice build up. Defrost for 24hrs and turn back on.If it happens again in the not so distent future then you have a bigger problem bit for now that would be my first step. 😉 hth
    #352640
    ent
    I’ve left the whole thing off for a month hoping it would drain the internal battery (if there is one) and reset but it didn’t work.
