Electrolux ENB39405S Leaking but no evidence where from?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux ENB39405S Leaking but no evidence where from?
  • #64472
    stu123
    When you look at the unit its leaking in the rear right hand side on the floor. The defrost timer outer case is wet but there is no clear evidence as to where the leak is coming from. The drain is clear and the dish on the top of the compressor is clear and not leaking. Any Ideas? Cheers
    #357185
    Seamy
    Re: Electrolux ENB39405S Leaking but no evidence where from?
    Had one doing similar a while back, found the water was runnning from poorly fitted pipe coming from fridge drain at the point where it comes out from fridge, the water ran down through the insulation & came out through the base of appliance near defrost timer. If there was an insulation breakdown on freezer it would weep & be wet also i’d imagine.
